Hi,
I want to toggle color on some module tap.
Created global variable list for example c_list with colors like #FFFFFFFF, #00000000, #......
the # is cleared out because it can be used as separator ok no problem. I have a list without # so FFFFFFFF, 00000000, .....
I created next global variable type (color) for example c_color and set it as formula where I add # something like this: #$gv(c_list)$ or $#+gv(c_list)$ it gives me corrected string like #FFFFFFFF ....
If I use this global variable $gv(c_color)$ and I will set it for some shape color for example and on tap action I will toggle the c_list list global variable the color of the shape is not changing.
Best regards,
Pavel
