Color Fonts
how do I keep the original color of fonts take a look at image below it is in playstore but how do i keep the original color of fonts? colorblobs KWGT - Apps on Google Play
font is here Nabla - Google Fonts
From the description in the Playstore i gather that the colors change according to something (“the mood”?).
If the creator of the widgets has blocked access to the contents of the widget (quite possibly so since it’s a payed app) then there is nothing you can do.
If you can access (parts of) the content we might be able to find where the color changing takes place.
not sure about color changing part because the time text color(yellow) is the one that is originally in the font preview in google fonts so i’m sure it’s either photo placed or it’s not possible since I checked every settings for text component in kustom. Color changing part might be about other widget text because we can see in the nabia font, it has that shade of yellow that is darker(shadow). I might have to get pack just to know how to get original font color.
I don’t understand well your question, but if you want to use this Nabla font with the yellow color you can use it as it is, load the variable font and in a Kwgt widget the color is yellow.
If you want to colorize it you can use in Fx the Texture>Bitmap and then colorize it here.
while colorize function is supposed to give color to whole element and what I wanted is that original shade of mixed yellow if the other color shade doesn’t work but colorize function paints whole text in whatever color you choose so that shade of yellow which is original in google fonts website is never to be found. To be honest I think none of kustom apps currently support color fonts that is the firsthand problem so it might not really be possible until support for it would be added.
UPDATE:- Don’t know how it was implemented in that pack if that is even implemented but I searched online and color fonts are considered experimental and is not supported at all in android platform.
