Color Filter
Clear filter doesn’t work in KLWP. I’ve checked KWGT and there’s no issues with it.
Which KLWP version are you using?
Version 3.82611411 Pro
I think the issue is related to the KLWP version. Try installing 3.81 and let me know if the problem persists.
It works in 3.81. Not a big issue because i use KWGT most of the time and it works there.
Glad to hear 3.81 works for you! It definitely confirms the issue is within the 3.82 build. There have been numerous reports about similar rendering bugs in this version, so at this point, we just have to wait for the developer to release a hotfix.
Looking into this, thanks for reporting
Confirmed. This is a fairly complex fix so not going to happen in 3.82
