Using Palette API (https://developer.android.com/training/material/palette-colors.html) can you add a method to extract colours from a specific part of an image? For example, extract the colour from the lower half of an image, or from the edges of an image.
This would be really really useful, please add this @frankmonza
Being able to define a ‘region’ for the Palette API to look at would make dynamic themes so much more accurate. Right now, if I’m stuck on a specific layout, I usually just run the image through Color Palette Extractor to pinpoint the exact hex from the area I’m targeting and then just set it as a variable. Having that native in Kustom would be a game changer for UI consistency though.
