Clipping mask on path shapes (svg)
I’m using an SVG path shape in the form of a lightning bolt. I used the recommended SVG Path Visualizer as suggested by Kustom. The shape renders correctly and also renders correctly in my Kustom widget.
The problem is that whenever I apply Mask > Clip All to the path shape, it AND the items beneath it (contained in the same Overlap Group) disappear in the widget. The path coordinates are still in the formula editor and the layers are all still there. According to Kustom, path shapes should be able to have clipping applied to them. Looking for guidance.
