Checkmark Komponent (no Tasker / no Flow) — Final Verified Version
https://imgur.com/a/rsIK98r
I spent the last few days developing and refining a fully functional checkmark component for Kustom — completely standalone, without using Tasker or Flow.
This was a challenging project, because Kustom doesn’t provide native tools for persistent state or timed resets, so I had to build the entire logic from scratch.
The component allows you to mark tasks as completed, and it automatically resets at the exact time you configure in the globals (24‑hour format). After many tests and fixes, I’ve finally verified that all checkmarks trigger at the precise scheduled time without any errors.
How to use it:
Place the komponent into your Kustom → Komponents folder, then load it in KWGT/KLWP from the library. You can duplicate it inside your preset as many times as needed and position each instance wherever your tasks are.
There are color controls for active/inactive states, and you can hide the circles entirely by setting their color to transparent.
Download:
I love stuff like this - community curiosity and sharing. Great job.
I’ll have a play with this at the weekend.
Thanks! Glad you liked it.
Feel free to test the komponent curious how it works on your setup.:+1:
