Cell/Mobile Iinfo Komponent for KLWP?
For years I have used a widget from the Network Signal Info app. But it has stopped working and I am seeking something to replace it.
It strikes me that something could be done with KLWP. Has anyone already done a Komponent like this that can be shared? I hate the idea of re-inventing the wheel here.
Thanks
This should be easy to build from scratch if you can’t find a Komponent. A lot of network info can be accessed using the NC formula.
RIGHT YOU ARE! Thanks.
Here is my result so far…
Credit to Brandon Craft for his video showing how to use the progress bar for this!
Awesome! We owe Brandon a lot. :slight_smile: This looks great. You should post this in the Share forum.
