Hi, I have a Pixel 8 Pro on which I downloaded the pro version of KWGT. I later purchased the Anything KWGT widgets package and loaded a widget for my music streaming app. It works, but unfortunately, the cover art for the song playing isn’t displayed. Can you explain how to do this? Thanks.
Have you tried to contact the creator of the KWGT widget that you purchased?
Or, perhaps you could share any screenshot(s) of the widget in the Kustom editor, so that we can help investigating how’s the widget work and what might be the cause of the issue you have.
Could also be the music player that you are using. If it doesn’t let KWGT “grab” the cover art, KWGT obviously can’t show it.
