Hi, so I’ve edited an existing wallpaper to fit what I needed and now can’t seem to load my current in use file as the file to edit.
I need to fix a touch, launch app, link. When I go to editor, it loads the original file from the download which has different apps and placements than what I’ve already changed and been using. The klwp app in the currently editing section has the original loaded too in it
How can I get my current, in use, file to be what appears in the editor? Id also like to export my current changes so I dont need to redo it
if you loaded the original file, the editor’s buffer is overwritten.
Your only chance right now: go to Load Preset and check the Backup tab. Your only chance right now is to go to Load Preset and check the Backup tab.
Look through your backups there.
Golden rule for the future: hitting the floppy disk icon only updates the live screen cache. Always go to the menu and hit “Export Preset” manually after making changes. It’s the only way to be 100% sure you won’t lose your progress. Good luck!
I dont see a backup tab anywhere. When I hit load preset, im brought to a page where the top says library, near the top it says currently editing, and below is wallpapers, which only 2 entries of the original and a different one I was trying out ling ago.
My only other buttons are a plus sign with creat, and a download button with import
