Can't get started, please help!
Hi, trying to create my first widget (Android 15). Searched web, tried Copilot and Gemini, you’re my final hope!
I downloaded the app from the play store, allowed all permissions that it asked for, and switched off battery optimisation following the warning.
Here’s what I’m trying:
Create a blank widget,
Select anything from Installed Packs → Base Pack, observed the Pro advert, hit ‘X’ to close it, observed the sad faces.
Now I see the editor, but there is nothing loaded, “This container is empty”.
I can sometimes add an item using the plus icon, but I can’t seem to edit it.
Main thing is that I want to try the base pack items before I decide if I want to go for Pro, but honestly it seems the app isn’t running at all correctly. Tried all combinations of clearing storage, specifying different folders, restarting phone, reinstalling app, different launchers (Moto default and preferred Nova Prime).
Please help!
Update…
I paid for pro and it’s working now. Clearly I misunderstood something, as I thought the base pack items would work without payment.
Thank you u/-_Dean_Winchester on Reddit for the advice!
Hey I’m having these same issues i cant load presets either and I paid for a widget pack and still giving me the same error message with the crying sad face any ideas or do i just have to buy it outright to use it
Yes, Buy the Pro Version.
