Can you send URIs from KLCK?
Is it possible to create URI links to other Kustom apps in KLCK? I want to change the layout of some kwgt elements based on what part of the lock screen is swiped on, but can’t find any URI touch interactions in KLCK
Yes, this should be possible. You can do this via globals using the format below.
kwgt://global/uVar/1
where uVar is a global variable KWGT and 1 is the value you want to set that global variable to.
