hi It’s a bit inconvenient to go to the settings window just by clicking the kwgt widget. Is there a way to disable it? And for music widgets, the playback bar does not appear in reverse or change.
device: galaxy s23 Ultra
In the root of the widget (in the editor) you can go to the touch menu. On standard there’s a touch setting there that says to open the editor. You can remove this.
Not sure what you mean by the playback bar bit in your post…
wow thank you and I meant for music widget,
my fav widget and currently using now, K19’s
is not turing to
when music is not playing it’s always
. and other music widgets,
when music is playing, and
when music stopped. they are swapped… (didn’t used translator for better understanding)
and thanks again to hear me. love KWGT’s work
That’s probably because some coding is wrong in the show and hide part (layer visibility) of those buttonlayers. Do you know a bit about the codes for doing that?
oh…I’m just a user and also don’t know why it’s happening
I think I can make similar music player by watching yt but,I’m sure I can’t make dynamic like other exist music players…
but hopefully, I just found pause and play button’s script and I may can insert image or icon
If you want, you can learn a bit from Brandon Craft. His tutorials are amazing.
Maybe that’ll help you fix the widgets you already have and want to keep.
Video is for KLWP, but the same goes for KWGT (minus the animations/live wallpaper stuff that he may be using at the end (not sure if they are in this video)).
ok thanks! I had trouble to edit k19 but I hope it’s helpful for me
Can’t find “K19” just now, so maybe a link?
Maybe I can help you out…
oh I was sleeping and woke up now but I can’t
copy the link cause it blocked
but ik it’s from koda for kustom
Found the widget and found the problem: the image that should have been the play button is actually an image of a pause button.
So you have two pause buttons, no matter what happens, you always see a pause button.
If you change the image it works like expected.
yea I tried to change but it didn’t work since
yesterday…and I found a widget that works well Feast 016. I didn’t used it cause K19 was looks better for me until yesterday. but, I made Feast 016 cooler than k19 now. I deleted white background and add colors it’s buttons. now Feast 016 is best ![]()
Good for you!
Post a screenshot of how it turned out?
Would love to see what you did.
yea! this is it. I exported it but it’s only for pro.
idk why but you can use it if you using pro
or tell me if you know how to make this for everyone to use that not pro like me :3
Looking good!
Might want to change the shadow of the cover, it’s overlapping the times.
You can only import widgets if you’re a pro user, not with the free app.
yea so I can’t use mine cause
I not bought pro lol XD
download aosp version it should work fine no pro required if you’re ok with ads KWGT Downloads | Kustom HQ
thanks! I solved all problems so don’t need to
