wherever i cut my car on the widget presets load blank (white) no spotify album cover or anything the coding also says failed to get bitmap
is there any way i can make them load properly on start
3.75b kustom app
thanks
thanks
It looks like a compatibility or a permission issue. Can you make sure that KWGT has access to notifications?
