Calender event compatibility
Help
Please I don’t know if it’s just me. But klwp doesn’t seem to be compatible with my calendars. Unlike kwgt, when I update my events, it doesn’t reflect immediately for klwp. I will have to enter the app (klwp) before it does. And that doesn’t even work all the time still.
And also, the touch action (url) works ONLY with my Google Calendar. I can’t access my other calendar events through the klwp touch action.
I have given every possible permissions. I would really appreciate an assistance. Thank you.
1
Have to checked your KLWP settings and choose which calendars do you want to show?
Settings ➞ General Settings ➞ Calendar to Show
Thank you. Yes I did check that. But it just doesn’t work. It only opens Google Calendar. And it delays to update events.
