Calendar events not showing on watch
I’ve added display of next calendar event. It shows fine in KWCH preview on my phone, but it’s not showing on my Samsung Galaxy Active 6. In KWCH settings I’ve selected the one calendar I want to see. I checked permissions on the watch and Kustom Watch Maker is in the calendar permissions list. Not sure what else I can check. Other purchased watch faces are able to display the next event.
This is not supported at the moment. Calendar data from your phone are not being synced by KWCH. Check if you can do this using complications in your device instead. I know Frank is already working on getting something like this.
Thanks for the tip Ace! I found my watch does provide a Next Event complication choice. So I changed the text item in my design to use the $cd(3, <>)$ notation and on the watch assigned Next Event to slot 3. I played around with title, stext, and ltext and found that $cd(3, ltext)$ hit the jackpot!
I’m very pleased with the power of KWCH. It’s so much better than the Samsung editor I had used with my previous watch.
How do I know if my watch has a complication like this and what exact information do I need to enter into KWCH for it to tell me the next event on my calendar? I use a TicWatch 3 Pro Ultra GPS.
If it runs WearOS then it’s most likely to support complications. Tap and hold on your watch face >> Customize. Check if this offers to configure complications.
Thanks for helping. I did what you suggested but nothing happened. First, I tapped and held on the watch face I created on KWCH. A icon of a gear that means “Settings” appeared. By clicking on this icon, I access the “data” and “about” options. By clicking on “data”, I have access to the options “slot 1”, “slot 2”, “slot 3” and “slot 4”. By clicking on one of these options, I have access to some complications such as calendar and weather. I chose weather but no changes occurred on the watch face. What do I still need to do?
May I know which formula you use to display the complication? Also, may I know which slot and data you assigned?
