Hi guys,
Since yesterday all my events are not showing. I use this Kode to display a picture based on the event of the day:
/storage/emulated/0/Pixel Launcher Concept/Google Agenda/Events/$ci(desc, 0, a0d)$.jpg
I have the right return but the picture doesn’t show. Same for the title of the event, the location, etc.
Is someone facing the same issue?
Ace
2
Could be an access issue. Try moving your images inside the Kustom folder and use the format below to pull them:
file:///Kustom/Pixel Launcher Concept/Google Agenda/Events/$ci(desc, 0, a0d)$.jpg
Hi Ace, thanks for the reply.
No changes. The issue is not only for the pictures. It’s all about the calendar preset. If I add a0d, it’s not working. Same for a1d, etc.
All the ci preset are impacted.
I do the same for the weather and the pictures are working. Only the calendar part is impacted.
Maybe an update will solve this issue. If you have other ideas, I take them ahaha!
Ace
4
Got it. Go to the app settings >> General settings >> Calendar to show. Set this to all and see if that will make a difference.
