Blur - FX
Sorry I posted this in request earlier...
I was wondering if you could allow more levels of Blur? Currently the radius allows from 0-25.
I would love to blur my images to a creamy gradation if possible.
Thanks!
This has been implemented in next (3.23) release. Blur will be possible up to 100.
Great! I would love to see blur as an animation in a future release of KLWP. Currently I have two options. Create two layers and fade them in and out. Or set a formula to adjust based on screen indicator. Thank you for your hard work!
Blur animations are not possible technically, blurring is too CPU intensive, everytime you see a blur animation its always a fade between a non blurred and one or more blurred steps.
I would love to see blur enabled not just as a blurred image or the background
I think this should be revisited, it’s been 8 years and blurring in an animation should not be that expensive anymore.
