Battery Information not updating
As seen in the screenshots, the widget is not updating battery status (Both battery percentage and charging status) on the launcher. It is accurate in the editor, and updates there instantly.
Device Information:
Nothing Phone 1
Nothing OS 3.0
Android 15
KWGT version: 3.78b510608
Things tested
  1. The status changes once after reboot, it doesn’t change after that
  2. Happens on both Action Launcher and the stock Nothing Launcher so launcher is not the issue
  3. As stated, it updates correctly in the Editor window
Same thing here. Both in KWGT and KLCK. Have seen issues with weather not updating always properly. I didn’t know if it had anything to do with globals associated with the battery widget.
Samsung s24+. Stock android 14 rom. It occurs as well across the 3 launchers I have tried: Nova, Octipi, and stock One UI.
Have had to go back to 3.78b510015 klck. Then it all works again for the lockscreen. Haven’t yet reverted to that version of kwgt as it would be too much work to redo everything…
Have already reported this thru the play store.
Same here. Seems global value %bi_level works only in edit mode, after adding widget to home screen it freezes and doesn’t been updated. Meanwhile use a Tasker variable but this is temporary solution and has to be fixed.
About an alarm: I have a Samsung Galaxy s25 Ultra and next alarm value contains any value but not an alarm itself, anything- calendars, Tasker, Routines app’s values, Samsung Find My Phone. It’s terrible, can’t use it in any scenario. Please, do something you can. If it possible at all, of course.
I just noticed that there are also issues with “next alarm” updating. It is now only updating after exiting the launcher and opening the phone again…
This seems to be a 3.78b version issue. I’m still on 3.77 and everything works correctly.
3.78b510015 worked fine. It is a problem with the most recent 3.78 builds 510607 and 510608.
I’m having the same problem as well. The battery percentage on my widget has been stuck at 95% since the last KWGT update. Although, it does show correctly in the KWGT editor.
KWGT Version: 3.78b510608
Samsung A53 5G, One UI 6.1
Android 14
When did 3.78 become beta? It was listed as release on the download page previously…
I any event, with “3.78 beta” build 3.78b510815,
The issues I had with power and next alarm seem to be resolved both on the Homescreen widget and on the lockscreen…
3.78 Stable Version isn’t a beta, but the others are still works in progress it would seem so they’re labeled as beta.
Can confirm this issue.
Me too, same problem from last apk update
I got the update “3.78b510818” on play store and that fixed the issue for me now.
