APP kwgt pro
Olá, comprei a versão PRO através do app gratuito, porém, na playstore pede pra pagar novamente se eu quiser baixar a versão pro, o q faço?
Welcome to the forum! Please write your questions in English so that the majority of our users can understand and help you. Thank you.
Regarding your Pro version issue: Don’t worry, you don’t need to pay again. There are two ways to get the Pro version: buying the separate ‘Pro Key’ app or using the In-App Purchase inside the free app. You chose the second one.
Here is what you need to do:
Do NOT download the ‘KLWP Pro Key’ from the Play Store. That is a separate license key for those who didn’t buy it inside the app.
Simply open the standard KLWP app (the free version). Since you bought the upgrade inside it, the Pro features should be unlocked automatically.
If it still shows as ‘Free’, make sure you are logged into the same Google account you used for the purchase. Sometimes it takes a few minutes for the Play Store to sync the license after a reinstall.
You can also try to tap ‘Restore Purchases’ or ‘Check License’ in the KLWP settings menu if available.
