few updates ago kustom add the ability to comment on formula but i don’t think ti’s officially written in the documentation. I’ll be nice to also put it in the example because i keep forgetting if it need */ or /*
Hello @Just_Robin
Here are the release notes for the feature.
Build: 3.71b308214
Uploaded: 2023-03-23T15:04:01.332Z
Release Notes:
- You can now C style use /* comments */ inside $kustom expressions$
- Brand new export dialog, feedback welcome!
- You can now export as image
- Flows can open URI and Intent links (so you can set Tasker vars)
- Flows can store any type of globals not just text globals
- Fixes new preset being re-exported causing duplicates
- Fixes music player info providing wrong package name
- Fixes feels like temperature not using provider data in AccuWeather
- Fixed “$wi(tempu)$” not changing when settings changed
Keep in mind that it has to be within the $'s
For example :
$tc(cap, "320" /*Use for 3.2 GB*/)$ will only show 320 for the output
Source :
