Add BLE cadence / speed
With the pro license of Kustom Widget, is it possible to create a widget that would display bicycle pedaling cadence from a cadence Bluetooth and/or ANT+ device?
Hi, this is currently not possible, i have moved this to the ideas section because its not too complex to implement and its a nice idea, Kustom has already Bluetooth access, i will give this a thought
After considering this i decided that its better to wait for Health Connect integration as ANT+ device data is better displayed in dedicated apps, nevertheless if the vendor will support HC it will work on Kustom too. Check out the following post to keep an eye on the development:
