Hi @all, I’m an absolutly newby in KWGT so sorry, if there will be some stupid questions…
When I create for example an Icon with several properties, I can click its checkbox and choose “copy”. But how can I paste it on the same or an other screen?
Thx Uli
After you Copy something, as you described, there should be a small icon, like a clip board, at right in the top bar to allow you to paste. However, frequently, it doesn’t seem to appear as soon as expected and I have to go up a level to a parent group and then back down to where I want to paste it and this time the Paste icon appears.
Thx a lot, so it works ![]()
