About the Issues category
Report bugs or issues with the apps
Please follow these rules when reporting a bug:
  • Search first for a similar issue
  • Provide details about the app you are using (klwp/kwgt…) the version and your Android release
  • Describe how the issue can be reproduced, what you expect and what you get instead
If the app is crashing and a bug report is required check this page for instructions to create a dump
