About text scrolling
How to use scrolling of text given by me horizontally using animating options and scrolling must be not stopped
You can add a non stopping scroll animation doing this:
  • Go to the animation TAB, add a new Animation
  • Select "LOOP" as type
  • Leave Scroll as mode
  • Tune the parameters so it will properly go out of screen
  • Move your object left if you want to have a ticker kind of effect so make it appear from the left and disappear on the right
Hope it helps
