hey , this is me , im making this post because of im still beginner also i have a bit experience to programming and i use java, while programming i always make a variable, and set the value , but when i am trying to use an app from Kustom Industries, i always confused about the global variable the one thing that make me confuse is , how can i learn to set the value for the global variable,and also i have a habit to use “=” to set an variable in any Kustom Industries app, is that correct, but in this end of my all the sentence at up , can you show me how to use global variable by sending the script??
You can learn about the global variable at the official website of Kustom:
You can also learn more on the YouTube channel of Brandon Craft, just search for global variable tutorials on his YouTube channel.
*Did you find the most helpful response to your issue?
Please kindly press the **
Solution** button to mark it as the solution.
This would help others with the similar issue.*
