After automatic update to 3.77 beta all widgets say loading and when attempting to replace them any preset that is loaded either comes up empty or totally messed up (it says loaded but only item on screen is a small square)
I’ve rolled back so can’t get pics but wanted see how many have same issue and what a fix might be
Ace
October 21, 2024, 1:51pm
2
Any idea which build of the beta you were using? Is it the one from here ?
frank
October 21, 2024, 1:59pm
3
Can you please share one of these presets?
frank
October 21, 2024, 2:00pm
4
Closing this since its a duplicate of:
I just received the latest update to KWGT v3.77. After the update, all widgets became “loading.” Hence, I uninstalled and reinstalled the app. Still, the widget is stuck at “CLICK TO SET UP OR LONG PRESS TO RESIZE,” even after I set up the widget. Please look into it. Thank you.
[Screenshot_20241017_220005_One UI Home]
frank
October 22, 2024, 12:45pm
6
This should be fixed on 3.77b429514beta
The new version is available on beta channel now and here:
KWGT downloads # Latest stable: 3.76 # Download: Google Play APK Build: 3.76b422110 Size: 32.60mb Uploaded: 2024-08-08T14:39:55.210Z
Variants # AOSP: 3.76b422114aosp (No PRO required, ADS supported, no Google Services) Huawei: 3.76b422114huawei (App...
