Can’t reorder Globals. I move them around, save it, export it. And they revert back to the order they were added.
May I know which exact build you’re using? This seems to be working for me on version 3.75b410013.
The same. From the play store update.
Android 14, April security patch on a pixel.
Ok, so I tried it on a new preset, I just created and it works.
