XML variable or use wg() with local text variables
Would be really useful to have our own XML file in the preset or komponent. Or any way to use wg() function with text variables (something like "wg(this://textVariableName)")
Why? It would work as predefined database. Yes, you can do it with list variables, but you need A LOT. Using XML files would make it more orderly and easy.
I could add a global of type "file" so a generic one that will be basically injecting a file in the Komponent, i like this idea
