My idea is quite simple: Add a Kustom Action that allows a change to a global text variable.
An example of where this could be useful is when defining "States" that require more than 2 options
i.e.
Background 1:
- Shape
- Touch Action - Write To Global - 1
- $if(gv(state) = 1, Show, Hide)$
Background 2:
- Shape
- Touch Action - Write To Global - 2
- $if(gv(state) = 2, Show, Hide)$
Background 3:
- Shape
- Touch Action - Write To Global - 3
- $if(gv(state) = 3, Show, Hide)$
frank
October 26, 2017, 12:53pm
2
Hi! You can do this already, actually in your specific case you can do this in 2 ways. Lets go through both.
Text Global
Lets say you want to just increment a counter always by one
Add a global of type Text and call it "counter"
Write "0" as value
Add a Shape, set touch action to "Switch Global"
Select the counter global
In the formula section write $gv(global)+1$
Done, your counter global will be incremented by one at each touch
List Global
If you want to cycle between a set of values (like 1,2,3) in your example you can do this:
Add a global of type List and call it "values"
Write "1,2,3" as values
Select the "values" global
Select "Go To Next" as action
Done, your global will go from 1 to 3 and back
Wow, thank you! This will certainly come in handy!
ok however it would be much more useful to be able to directly modify the variable from code. for example: in a loop cycle, being able to perform calculations and then subsequently save them in a variable for later use. as it is now the variable can be practically changed only with a direct interaction from the user, which is not exactly the best
"In the formula section write $gv(global)+1$"
Doesn't work for me. The counter variable is named "counter" as per your first step, so the formula should be $gv(counter)+1$.
