https://imgur.com/a/U5y7Y1O
I can't seem to get the month to come out fully on the widget, in the text field i have the code $df(MMMM)$ but for some reason the month won't display fully.
I've tried playing with the height of the box and everything but cant figure out a way to get the whole word displayed.
Try to play with the width, I think that if you use a font size of 80, you can use a width of 50 if you are using uppercase text filter.
I think that you can use $df(MMM)$ to have only 3 letters of the month, if not in large months like september the text are going to go out of your box.
turns out it was the width, thanks man!
