Hello,
I don't know if it's because of an update but after restarting my phone my widgets got truncated. It seems that the ratio in app doesn't match the one on my home screen and I don't know how to fix that. It worked perfectly fine before I restarted it and I hadn't been modifying the widgets for a few weeks before this happenened.
Thank you
[Edit] nevermind I fixed it by changing the settings of the widgets' size (my app is in french so I'm not sure how it's called in English). I don't know why it changed but everything's fine now, I'm not deleting this post in case someone else encounters the same problem
