Widgets on "Discover" section
Are there eligibility requirements for adding widget packs here?
I think this list is manually generated. I suggest you contact @frank to see if he can add one for you.
As @Ace said this is a manually managed list. The only requirement is to have a free and unlocked pack, you can comment here:
Or send me a DM if you have a pack like that, i can change the list anytime.
