All my widgets got bigger, just slightly, but noticable. Was that a update or what happened?
(Note: I have all my sizing done with “pxls/si(skpi)”)
Update: Could be a problem of my launcher, the spotify widget itself has an imperfection (not my custom widget)
Update: Can fix the (non-kustom) widget with smallest width setting, but now I need to recheck my kustom widgets, because of the original bug (smallest width doesn’t effect kustom)
That’s interesting, as mine keep shrinking, by very noticeable amounts. Most of the time they’ll fix themselves upon restart, or simply waiting it out long enough, but it is very frustrating when it happens, especially since I’m pretty much blind at the moment, lol!
Interesting if it happens randomly, but I know of that bug, if you resize the widget. My workaround for that is making all widget values to pixels ( Number*si(skpi) ).
I hadn’t touched it, it just happens randomly, but I’ll try changing the values and see if it still does it. Thanks!
