There's a relatively frequent bug in which a random widget will trigger the touch action of another widget, and when scrolling to the other supposed widget, it's completely buggy and cut off and zoomed in, basically unresponsive, until it's triggered. If the KWGT app isn't force closed and reopened, it basically keeps happening over and over. I attached a screenshot of the widget at the bottom showing how buggy it is. It's supposed to be a 4x1 wide widget, showing storage, ram and battery, but it's unresponsive and cut off until manually triggered which seems to update it. Keeps happening.
