Hi. I just started playing with this awesome app, but I can't get around this problem. Entry widget I make keeps randomly resizing itself on the screen as I sit and watch. First, I had an issue after export where the contents of the widget was super tiny inside the frame and resizing it as big as the entire screen barely made it any bigger plus it's fuzzy. I found out how to change text size, to like 350, but about 15 seconds after placing it, it shrank on its own. Then I found scaling, but same thing. I have a couple ideas of what it could be. .. I'm on a tablet. .. something Nova launcher is doing is causing it. Maybe? Thanks for your time.
Same is happening to me and I cant determine the fix
