Widget problems
Hello,
After I make my adjustments, I save and set the widget, the widget will need readjustments 4/5 times throughout the day because things become to big, move to a totally different spot, or everything is on top of each other each. Also, if I set a shortcut to a komponent, for some reason it disappears and I have to do redo the shortcut. Unfortunately, new update didn't fix this ongoing problem.
