So I can drag a widget onto my homescreen, but I cannot click it at all. It just says "click to setup...". I can't click on an already existing widget either.
So far I've tried:
-reinstalling KWGT and the pro key multiple times, different orders etc
- restarting my phone
-changing launcher
-resetting phone
But none of these helped. This problem has occured for 1 Week now, and I am using a Xiaomi Mi 9
Hello,
I resolved this problem by following these steps:
- Place a widget
- Long press on the widget and choose 'App info'
- Select 'Other permissions'
- Select 'Start in background' and change to 'Accept'
Hope this works for you too!
It actually did. Why didn't I think of this! Thank you very much :)
Yes, I had got the same issue on MIUI 11 on MI8 and I solved it with this indication
i do anything above but nothing works. so i put clock widget from stock android because i can load any widget to homescreen (nothing happened when i click widget area)
Miui11 - Nova Prime
(but in miui launcher i can add any widget from klwp)
