Widget lock
I was wondering if there's a way that I can "lock" the widgets so that the kwgt widget editor screen doesn't pop up when I accidentally tap the widgets that I have while I'm scrolling through my phone
Just remove the touch action, you can find it in the "touch" tab on the root layer, just select it and press delete.
