If KWGT resize set to auto, then changing the widget multiple times can lead to weird measurement. The si(rheight) or si(rwidth) usually getting bigger even after reverted to previous size.
Thanks will look into this
I had this issue too, it appeared in one of the 3.74 beta builds, but the final release fixed it for me. Maybe try installing the new version? Not sure if its on the play store yet but you can get it here: KWGT | Kustom HQ
