Why is the widgets or shapes not visible
I have created 4 images ,in the root folder,and I need to setup a button like thing to ,make the wallpaper changes,but when insert it ,I don’t see the shape,or widget in the home screen,but I could clearly see that in the klwp app,and also I have tried to create it through component section,and also by creating overlap inside a component,also tried putting shape or widget thing directly in the root folder.
Can you share the preset here so we can reproduce the issue for you?
No problem mate I changed my idea and changed my idea for a new theme,but wherever I go, problems tied to me.
So I got the json file and two jpgs from a creator,and I applied it,like compressed and renamed, .klwp instead of .zip and then loaded the preset.
It worked fine for a little while and then started malfunctioning ,I couldn’t interact with the theme/setup in the desktop but I could in the editor.
Yeah it’s a pain in the a**
It works fine in the editor though,I mean I could interact well
What launcher are you using?
And is the problem the same for every launcher?
Nova launcher,is it the problem with the launcher?!
Probably not (since you’re using Nova), but it’s always worth the try…
OneUI for instance has some trouble with handling touch actions.
