Everything on Wget category doesn't seem to work on my galaxy s6 device.. it only shows "Loading..." No matter what and p ick a random file/image return blank
I use Nova Launcher Prime on an unrooted phone
Please help
Please help
This is normal, the WGet function will not load anything in the editor, WG() will load only when you add content to your real widget or wallpaper. So you need to add that to your setup, save, and then wait, content will be loaded and then show up on the editor too. This is too avoid having a lot of not needed cache files.
oh, i see
i'll try that and report back (:
so i checked, and it seems to just stay on "Loading.." i have no idea why
Any updates on this. I'm not able to pull in data from an api
