Weather Underground as a weather provider
Please add Weather Underground as a weather provider.
Hi! Unfortunately at current stage Weather Underground APIs are too expensive and using it inside Kustom will not be possible. HOWEVER i am planning to develop a way to create weather plugin with external apps, once that will be available more providers will be distributed including Weather Underground.
That is understandable. A plugin for external apps would be awesome!
Would it be possible to use Weather Underground, but make us get our own key? WatchMaker does this. I'm assuming this gets around the developer having to pay any API costs, which is good since the Weather Underground API keys are free for personal use.
Can not wait!
This will be available as a separate plugin with own API Key or Subscription starting from 3.26 out in beta 1-2 weeks from now
