Hi,
I am able to see the temp data from the weather complication 1 by using $cd(1, title)$
Does anyone know the syntax for the status e.g. Sunny, Cloudy, Raining?
I have tried ltext but this displays the district/town.
Thanks
Chris
Hi,
Thanks
Chris
Hi,
Here are the weather info syntax
and here is the weather forcast .
I’m not 100% sure how you would kode it, as you seem to be calling for data from complication data, so these might have to be used as seperate kode? I’m new to all this myself
Best of luck
Using complications, you are limited to the weather data that you can assign to a complication.
ltext works for me.
The preview text for complication data in the KWCH App is not correct in my case.
For complication data I can only see the “true result” on my watch.
Make sure to assign weather to complication 1 in your watch app.
