Weather not working on andrion 10 galaxy note10plus
I just bought galaxy note 10 plus dual Sim. I'm not root it yet but the problem is all weather icon doesn't work anymore on Android 10. How I can solve this problem?
Maybe you can test other weather provider, or put other weather icon komponent in your preset.
Thanks. Problem solved after changed weather provider.
