My weather refuses to update with any provider. I tried setting the location manually but it still doesn't update.
This is a stock lg v500
Hi! It appears that Kustom is not able to detect your location correctly, please check the following:
If you still have issues with the above try setting a default location (as you did) and change provider before forcing an update, this should work, if its still not working please create a debug dump from the settings (last option) after the force update and send it to [email protected] mentioning this thread.
Did you get this solved?
