Hi
I simply cannot get weather to show accurately or update.
When I force update from within Kustom app I get this:
Any idea what I'm doing wrong?
Regards
Hi
Regards
This means that no widget on screen is currently using weather, if Kustom is not using weather at all weather is disabled, you need to load a theme that uses it or add some weather info in your setup.
