Weather not updating - India
Not sure what's wrong but weather does not work. I get ?? instead. I have provided the location permission, location is set to high accuracy, tried changing service provider. Nothing seems to be working. Anybody knows solution to this?
Maybe you can set your location manually and see if this solve the problem, and you can use media energy
Tried setting location manually. Did not help with weather tho'
Hi👍 I remember other users reporting same problems a few weeks ago. The problems solved by itself,
this might happen if geo coder is for some reason gone, this is an android functionality, sometimes starting google maps help"
This is an answer from the developer to other user, maybe this can help you.👍
