Weather api information not displaying on home screen
I am currently using the weather underground api to get and chance of rain forecast because it's the only way I've figured out how to do it. I've had the problem for a long time now on a few phones that if I'm in the text editor within the Kustom app, it properly displays the information from the api. But if I save and go to my home screen, the information is not shown. I know it does / can work because it correctly pulls the information from the api and has worked intermittently in the past, but most if the time, it doesn't display the information at all. If this problem could be resolved, I would greatly appreciate it. Thank you.
I would require a full debug dump to debug this further however i would suggest you waiting for 3.26 where i will add chance of rain as a new field for supported providers and also a plugin to get the weather from WU either using your own api key or a subscription
Me pasa lo mismo y tengo la última versión
