Wallpaper glitches after a few minutes
I have a problem with the wallpaper moving from page to page. I have it enabled in Nova, and it works when I save the preset, but after a few minutes, the wallpaper won't move anymore. If I open up the app and click save, it'll fix the problem but it comes back after another few minutes. It might be because I have a gif set up on the second page. Is there anything I can do to fix this for good?
So you are using an animated GIF inside the preset? If yes it might be a bug related to that, please check the second mentioned method here: http://help.kustom.rocks/i193-send-debug-data (full Android bug report) and send everything to [email protected] together with the preset mentioning the thread, will look into this.
