Visible only on launcher homescreen
Hi. Do you think it's possible to add the option "Only on launcher homescreen" in Layer>Visible menu?
It should remove the modules while you are not on homescreen and basically they are not visible or at least useless.
It should help reduce resources usage, and it could also be used to create nice effect when showing app drawer.
Just don't know if it's possible for the app to discriminate such a thing by interacting with every possible launcher.
